Pealkiri: 2006 Superb ja rida veakoode (Vastuseid: 3 | Vaatamisi: 3835)
ricardo25
Registreerunud 27.09.10
Auto: skoda kodiaq rs 2019
postitati 10.04.12 16:18 Tsiteeri
tere
panin täna kaabli külge oma suksule
kas keegi oskab,viitsib tõlkida
dress 08: Auto HVAC Labels: 3U0-907-044.lbl
Part No: 3U0 907 044 A
Component: CLIMATRONIC S B5 C 2004
Coding: 17000
Shop #: WSC 00028
VCID: 316D11F7D1B9
3 Faults Found:
01272 - Positioning Motor for Central Flap (V70)
37-00 - Faulty
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
27-10 - Implausible Signal - Intermittent
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 00028
VCID: 2F69178FC78D
1 Fault Found:
Address 17: Instruments Labels: 3U0-920-xxx-17.lbl
Part No: 3U0 920 841 A
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 31115
Shop #: WSC 00000
VCID: 316D11F7D1B9
TMBBU63U459093039 SKZ7Z0E2856348
1 Fault Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: F0EB54F39A33
1 Fault Found:
Address 36: Seat Mem. Drvr Labels: 3B1-959-760.lbl
Part No: 3B1 959 760 E
Component: °301
Shop #: WSC 65536 039 00000
VCID: 2F69178FC78D
13 Faults Found:
01008 - Note; Emergency OFF Switch is Active!
000 - -
00994 - Sensor for Front Height Adjustment On Drivers Seat (G215)
007 - Short to Ground
011 - Open Circuit - Intermittent
00995 - Sensor for Rear Height Adjustment On Drivers Seat (G216)
01009 - Sensor for Driver's Seat Position Fore/Aft (G218)
01010 - Sensor for Driver's Seat Recline (G219)
00999 - Motor for Front Height Adjustment of Driver's Seat (V29)
000 - -
01000 - Motor for Rear Height Adjustment of Driver's Seat (V30)
000 - -
01173 - Motor for Driver Seat Fore/Aft Adjustment (V28)
000 - -
00998 - Motor for Driver's Seat Recline (V45)
000 - -
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: BB Komfortger&#303;t HLO 0004
Coding: 00259
Shop #: WSC 00028
VCID: 366722EB38D7
Part No: 1C0959801
Component: BB Tõrsteuer.FS KLO 0202
Part No: 1C0959802A
Component: BB Tõrsteuer.BF KLO 0202
Part No: 3U0959811
Component: BB Tõrsteuer.HL KLO 0202
Part No: 3U0959812
Component: BB Tõrsteuer.HR KLO 0202
2 Faults Found:
00933 - Electric Window Motor; Passenger Side (V148)
62-10 - No or Incorrect Adjustment - Intermittent
Address 76: Park Assist Labels: None
Part No: 3U0 919 283
Component: Einparkhilfe V009
Coding: 01114
Shop #: WSC 00028
VCID: F8FB6CD3F243
2 Faults Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
03-00 - No Signal
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
29-00 - Short to Ground
postitati 11.04.12 05:36 Tsiteeri
Kui inglise keelt jagad, siis saad kõigi veakoodide tähendused
http://wiki.ross-tech.com/wiki/index.php/01336
Vaheta lõpus olev kood ära või otsi koodi järgi.
ricardo25
postitati 11.04.12 15:34 Tsiteeri
ma arvan et need vead on seotud comfort blokist ühesõnaga peaks selle blokki ära vahetama
postitati 11.04.12 16:11 Tsiteeri
Üsna tõenäoliselt küll. Tagumised parkimisandurid võivad lihtsalt niisama läbi olla.
[PHP: 22.1% - SQL: 77.9%]
