Deprecated: Implicit conversion from float 255307.99999999997 to int loses precision in /data01/virt4271/domeenid/www.audiclub.ee/skoda/viewthread.php on line 167
Eesti Skoda Klubi - välistemperatuuuri andur
Pealkiri: välistemperatuuuri andur (Vastuseid: 1 | Vaatamisi: 3017)
2rni
Registreerunud 16.09.15
postitati 28.02.16 15:14 Tsiteeri
octavia tdi 1.9 66kw 98a. omal peaks olema see andur, aga kus see asub? peaks asuma seal http://s64.photobucket.com/user/pyrant/media/01062011396.jpg.html
aga ei ole, mingi lahtine pistik on aga sinna ei istu see
http://www.ebay.co.uk/itm/SKODA-OCTAVIA-FABIA-PRAKTIK-OUTSIDE-AMBIENT-AIR-TEMPERATURE-SENSOR-/171078265343
armatuuris ei näita midagi aga, kui alles hiljuti käisin viljandist-tallinna, siis tagasitulles oli need
--,--°C. seega peab olema see kusakil
2rni
postitati 22.03.16 14:13 Tsiteeri
VCDS-Lite Version: Release 1.2
Tuesday, 22 March 2016, 15:28:25:0
Chassis Type: 1U - Skoda Octavia I
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,56,76
Address 01: Engine Labels: 038-906-018-AGR.LBL
Controller: 038 906 018 BC
Component: 1,9l R4 EDC 00SG 1822
Coding: 00002
Shop #: WSC 31480
VCID: 58C30B63AB0B
1 Fault Found:
01117 - Generator Terminal DF Load Signal
27-00 - Implausible Signal
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.LBL
Controller: 1J0 907 379 G
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 31480
VCID: 351DA2D71C59
3 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
35-00 - -
16-10 - Signal Outside Specifications - Intermittent
04-10 - Mechanical Malfunction - Intermittent
Address 15: Airbags Labels: 1J0-909-60x-VW3.LBL
Controller: 1J0 909 603 B
Component: AIRBAG VW3 - V04
Coding: 00066
Shop #: WSC 31480
VCID: 28237BA3DBEB
No fault code found.
Address 17: Instruments Labels: 1Ux-919-xxx-17.LBL
Controller: 1U1 919 033 G
Component: A+-KOMBIINSTR. VDO V19
Coding: 02140
Shop #: WSC 31480
VCID: 3701A8DF0655
IMMO-IDENTNR: SKZ7Z0W0134252
1 Fault Found:
00667 - Ambient Temperature Signal
30-10 - Open or Short to Plus - Intermittent
Address 46: Central Conv. Labels: 1J0-959-799.LBL
Controller: 1J0 959 799 L
Component: 0W Zentral-SG Komf.0002
Coding: 00256
Shop #: WSC 31480
VCID: 47E1D81F76B5
8 Faults Found:
00949 - Central Locking Motor - tailgate (V53); LOCK
25-10 - Unknown Switch Condition - Intermittent
01329 - Convenience System Data Bus in Emergency Mode
35-10 - - - Intermittent
01332 - Door Control Module; Passenger Side (J387)
49-10 - No Communications - Intermittent
01331 - Door Control Module; Driver Side (J386)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
54-10 - Incorrectly Equipped - Intermittent
53-10 - Supply Voltage Too Low - Intermittent
27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
End --------------------------------------------------------------------------------------------------
siin on näha, et siin on see olemas aga ei leia!!!!:mad::mad::mad::mad::mad:
[PHP: 19.8% - SQL: 80.2%]
